Two circulators together
10 Feb 2007
Cumbria
If I placed two circulators in same 22mm pipe (same flow) would this create any problems apart from double the pressure? If one stopped due to a fault would the other still function ok?
Do you mean, if you add another pump will your heating work properly?
A. No,
Was I right?
What system/boiler you got?
What problems are you having?
I've been doing this job for 30+ years and I've never added a pump to solve a problem.
I have seen where a second pump in series has been used to overcome a flow problem!
Better to solve the original problem in my view but that's often undersized pipework so not quite so easy.
Tony
