Hi all
I would be really grateful for any advice on these two dishwasher problems that I have encountered over Christmas: -
1. My Bosch Dishwasher (about 4 years old) appears to work normally, the cycle obviously completes successfully and everything has obviously been leaned well. But on close inspection on some mugs and nearly all tall glasses, a grainy deposit has been left on the inside at the top - this looks like a silty/sandy grainy deposit that dries hard and is very difficult to shift afterwards. I have cleaned the dishwaher with one of those cleaning capsules that you can get for about £3, but this does not seem to have helped. Do you think there could be a problem with the waste pipe feeding dirty water back into the dishwasher?
2. My parents-in-law's Hotpoint dishwasher (also about 4 years old) also suddenly developed a problem. The machine suddenly stopped filling with water. You can hear a low rumbling sound, which I assume is the pump tryin to pull water in, but to no avail. I checked the water supply and it is fine. I changed the supply hose, just in case there was a kink in it. This appeared to fix it. So I put the dishwaher back into position against the wall and tried again. It seemd to start fine and I could hear water coming back in, but about half way through the cycle it seemed to have problems again an reverted back to square one. I checked and re-checked all water connections and they seem fine.
I would be most grateful for any advice/help on either of these problems!
Kind regards
Jon
Kind regards
Jon
