Prima LPR 600 Dishwasher
12 Oct 2009
Sheffield
Can anyone help? I have just bought a house with a Prima LPR 600 integral dishwasher, but no user manual. The dishwasher seems to be working ok except that the dishwasher tablet door does not open during the washing cycle. The dishwaher fills up, heats up and goes through all of the washing and rinsing cycles but as the soap tablet has not been released the pots are not clean when it has finished. \Does anyone know what the problem might be? Is there a simple fix or do I need to call out an engineer? Also, I've heard that this model is the same as a Whirlpool dishwasher. As I can't seem to find a user manual on the web for the Prima LPR 600, if anyone knows the Whirlpool equivalent I may be able to source the manual for that.
Thanks in anticipation......
Thanks for the info. Do you know if the replacement is straightforward? In the link you supplied the picture of the the tablet and rinse aid doors are not the same as mine. Does this matter? Thanks
it is simple to replace
undo the screws on the inside of the door , the front panel should fall out so be ready to catch it. the soap draw will become visible. make a note of the wiring. to release the dispenser , some have six screws and 2 fixing brackets, some just require the metal flanges to be bent out.
watch out for razor sharp edges and ensure the machine is unplugged
it is good to get a matching one but not always neccessary, all whirlpool ones work the same
Thanks for your advice. I'll have a look at the weekend to see if I think I can do it!
Took the panel off at the weekend and found that the plug in wire that goes into the back of the soap dispenser to power the solenoid had come loose. I simply plugged it back in and it now works perfectly!
Thanks once again for your help.
