Can anyone help? I have a Prima LPR 600 and the drain pump is running continously, even when opening the door. This fault started with the START indicator lamp flashing but no water in the dishwasher. Any ideas?
Not much info out there about this model. It is a rebranded Whirlpool. I believe that if you hold the start button for about 10 seconds it is supposed to re-set the appliance.
That indicates a flooded base.
Pull it out, tip it back about 45 degrees (some towels around the rear are needed) and drain the base. Try it again, if it fails again you've probably got a leak into the base.
Don't use 3, 4 or 5 in 1 tablets as well as rinse aid, this overfoams and floods the base.
Hi Sleepyhead - Thanks for the reply. The fault now seems to have changed. At the start of a cycle the pump runs for a while and then the machine beeps and there are now 4 flashes between pauses.
4 flashes indicates a drainage failure.
More likely the black grid in the sump is clogged, carefully clean it out taking care not to damage the internals.
The machine appears to drain OK. I have filled it several times with water and allowed to drain into a bucket. There is good flow and the water comes out clear. The black filter looks clear. Can it be removed for cleaning?
