Hi, I am not a plumber and am currently having an 'discussion' with one. Just after a basic answer.
New UFH and boiler (not combi) installed to a new kitchen extension in Dec. Boiler drives HW, CH and UFH independently as you'd expect. Works fine on the first two, however when the thermostat calls for heat for the UFH, boiler comes on and then constantly switches on/off/on/off (about every 5 mins) during the demand period.
Makers of the UFH (Nu Heat) advised on needing a auto bypass valve for when the pump is unable to dissipate the heat quickly enough and that will cure it. Makes sense. Plumber says there already is a bypass fitted but it is in the airing cupboard which is upstairs and about 7 metres from the manifold.
Now, I know that when ANY of the demands are made to the boiler, the heated towel rails in the two upstairs bathrooms also come on, so I understand that the water is somehow looping upstairs before or after heating the UFH, however is it right that the bypass is up there as well or should it be closer to the manifold? Nu Heat techs say that if correctly fitted, the bypass valve will stop the boiler from having to switch on and off.
Would love any independent views on this.
