Hi all
Hope the experts can help as more people I talk to the more I am getting confused. I am getting some work done and will be UFH in the extension however I would also like it in my existing property as it will be open plan. The existing property is built on a raft foundation and was built in 1990. As far as we are aware there is no insulation. There are two options I have been told I have. An overlay board which will decrease my height of ceiling which is already quite low. Or I can get grooves milled into the existing concrete. The main question I have is that regardless of both I will be losing heat below but which is the two of the lesser evils as such.
*Is there much difference between heat loss between an overlay board or milling?
*Is losing the height by using an overlay board better for heat.
My builder has said we cannot dig down on Raft Foundation as this is what is supporting the house as I was looking into options of digging down 150mm. Put down 100m insulation and then 50mm screed on top. Is this the case and you cannot take out 150mm from concrete of Raft Foundation.
Thank you for any advice you can give.
