As for humidity, why not have a small indoor fountain?
I too considered this until I discovered that the size of the fountain would have to be very large for it too maintain a reasonable level of humidity in relation to the room size. Our lower floor is only about 45 square meters and the waterfall/ fountains droplets would cause a damp zone...sorry guys it sounds a good idea but it won't work in a domestic environment unless you're prepared to have a damp area or a splash zone. A humidifier causes the water droplets to take the form of vapour and becomes airbound in such a way as to spread more evenly throughout the room, subsequently the room never actually feels damp.
the only trouble they find is that it is too slow, in that if it is hot out it takes a while to cool down and if it is cold it takes a while to heat up, in either case it can be up to 12 hours
This exactly why I installed small rads on the circuit. During my research period leading up to my own installation many people that I spoke to that had already installed UFH, complained about the warm up/cool down periods. Using small rads the room has a fine control feature. Of course if the weather has been cold for a long period and suddenly turns warm there is still a cooling off period. However the room temperature can always be reduced by opening a window.
Reiterating a point I made in an earlier post, the rads also allow me to use limiter valves, they look like the normal rad stat valves, but I can control the individual zones much more effectively than a room stat would.
