Under sink water heater
Thanks was just looking at the Triton instaflow ones that come with flex and a plug on the unit
Yes, if no more than 3kw. Always check the manufacturer's instructions as well.
Thanks, the Hyco ones say they should be connected to a double pole fixed fused spur. 13 amps. The appliance is 2kw
The one I looked at said it "should" be connected to an FCU, not "must". I would use a plug if I needed to.
Thanks I've done the Hyco ones before and I'm sure they used to recommend connecting to the 1/2male threads on top of the unit with flexis? Just downloaded some instructions no mention of flexis. I think I'd prefer to use 1/2 females to 15mm compressions
