Hi all,
Firstly very grateful for any advice received.
In my house I have inherited a hybrid underfloor/radiator - oil fired central heating system. The previous owner was an 'irrigation engineer' and very much liked concrete. He lifted all the floors and installed a wet piped heating system - covered with a sort of fibre infill and then with around 5 inches of concrete as far as I can tell. This is all connected to a bespoke manifold with taps to all the underfloor sections - controlled by gate valves - I have a cupboard that could pass as part of a ships boiler room. Upstairs there are 4 radiators for heating - giving about 6 Kw at a guess. Hot water is taken care off via a conventional hot water tank - gravity system. The system is open vented with a loft tank for expansion. The underfloor heating works OK - the boiler runs and the pump circulates the water and the UFH slowly warms up the floor - boiler switches off and the UFH slowly cools down - never feel 'roasted' but never feel cold. The problem is that the UFH is fed from the manifold with what looks like 22mm pipes - 8 in total, whereas the upstairs rads are fed from a 15mm spur - not a great deal of heat gets upstairs - and takes a long time getting there. Because the water gets slowly warm for the UFH - larger volume with slower heat dissipation the radiators upstairs only heat up slowly - like really slowly. I suspect that the flow rate is insufficient - even with the rads at minimum resistance to flow. Suspect that 1x15mm v 8x22mm does not help.
My question is - what would be the best way to increase the volume of heat reaching the upstairs radiators (they are on a conventional parallel circuit spurred from the underfloor system manifold). I am a bit reluctant to throttle down the UFH on the manifold to try and increase the radiator flow - visions of installing a new set of 8 gate valves (hate them) or unnecessarily pressuring the system at that point. Would it be feasible to place a small pump on the 15mm section for upstairs to increase the flow. I could then cannibalise some of the hottest water from the output manifold for upstairs. What would be the best way to regulate this type of arrangement - I would not want the secondary pump to pull all the hot water away from the UFH.
Many thanks for your help.
