Hello
We have underfloor heating controller by a controller attached to the wall.
Whenever the controller attempts to switch the heating on it resets itself as if I switched the socket off then turns back on with factory settings therefore the heating never actually switch on.
I thought it might be the fuse, I replaced it but it didn't solve the problem.
Is the problem likely to be with the controller hence I need to replace it (should be cheap and simple) or the heating itself (complicated and expensive)?
