Underfloor Heating General Question and Wiring Concerns
20 Nov 2008
Nottingham
I've done a lot of searching on the forum and can't seem to find comprehensive answers to my concerns, so I'm hoping you guys can help.
We're considering underfloor heating in the bathroom which is on the ground floor. 2m wide x 2.6m long x 2m high, concrete floor i think.
The only electrics in place at that end if the house are lighting circuits so a new wire will need to be run about 10m from the basement on its own RCD, under the floorboards and down the back of the kitchen units to the bathroom to allow the wiring of the UFH.
1. Should, in this circumstance, the supply cable be buried in the wall on its route from the basement to the bathroom? Or can it be fixed to the wall?
2. Also, does the installation of UFH have to be declared to my local planning office or whoever you declare this stuff to?
3. I did some rough calcs and the rad in there at the moment outputs approx 425w and the underfloor outputs 450w so the room should be quite warm without the radiator in theory.
4. Can the thermostat be fitted inside the bathroom so that air temp can be monitored rather than using the floor probe? I'm guessing the answer is no, but wanted to check.
All wiring would be done by an approved Sparky.
Thanks in Advance,
John
Or I could go with a fused spur from one of the upstairs circuits possibly? Might be over thinking this.
