Thanks for all the comments.
The clipper plates are circa £5 each plus screws/fixings and we need 300+ so obviously we wanted to look for other solutions to have a couple of grand!
Would it be possible to clip the piping to the underside of the chipboard (from below) & then 150mm mineral wool insulation underneath. Feed the pipes through the metal webs. Joists are spaced at 600mm.
Problem fitting from above is we would have to cross batten the deck which raises the floor height as we cannot drill/notch the metal web joists unlike traditional joists.
Yes very labour intensive but fitting ourselves. Any problems with this method?
Thanks to those who genuinely tried to help
Fixing to the underside of the flooring means you're heating air & not a thermal mass. Sorry mate, I've just noticed you have web joists.
If the joists can take the weight, I'd lay 12mm OSB on top of the joists, then 50x25mm battens, pipes between the battens & screed. Thermal mass is king!!
