Hi All,
I moved into a house last year which has warm-up underfloor heating fitted in the bathroom. Has always worked fine, but when a colleague had it fitted at his place, the sparky had fitted it on an RCD (for obvious reasons) so I checked mine and found it to just be on a 3A switched fused spur.
I decided to change this for an RCD to be on the safeside, so did that over the weekend. Everything was working fine, but when I woke up this morning the RCD had tripped and the floor was cold. I reset it and it came back on fine, and was on and warm when I left the house, but what could be causing it to trip?
The thought of taking up the slate floor to re-lay the heating doesn't appeal in the slightest, but I obviously need to know things are safe.
I know the official response will be to get someone in to test it, which I will do if necessary, but is there anything easy I can test myself?
Cheers
Cheers
