Hi all, i've read quite a few different threads on installing installation under the floor, particularly around ensuring there is adequate air-flow to avoid damp. We're in the process of ripping out our current flooring, and as the house (circa 1900 build) is very cold in winter, we're looking at options to improve installation.
The concern we have is right now is whether installing insulation and sealing the floorboards / skirting etc. may creating a risk of damp on the joists. We're nervous the sealing / insulation itself will reduce any air-flow that was occuring from the living areas, and as the basement ceiling is flush with the joists there is limited opportunity for air to move under the joists. From inspection, we have only 1 air-brick (rear of property) and nothing on the front (or it has been rendered over).
No visible damp issues on joists currently, but would the installation of insulation and sealing significantly increase risk of damp? If so any thought on best option (e.g. installing further air-bricks - would this even help given the basement celining is flush with the joists?). Unsure how to protect against the risk of damp (with any degree of confidence) to avoid having to pull the floors up all over again!
Thanks Much!
Thanks Much!
