masona said:Is it posible to undo crimps with the racket crimper?
Or is it clean cut the wire and start again?
why would needing to re-use the crimps effect removin the socket?masona said:Okay, the plug is so awkward of pulling it out of the IP56 socket (have to move it up, down & sideway to release it.) I was going to replace the socket unless I can spray lightly a Servisol super 10.(switch cleaning lubricant) If so, is it safe to do so?
OOOh dohandrew2022 said:why would needing to re-use the crimps effect removin the socket?
I'm not ready for that yetbreezer said:cant remember what its called or who makes them, but i have seen a "plastic stp thing" that you put over the plug pins before you plug it in.
It loops over the plug, and the excess forms a loop for you to use to make pulling the plug out easier. i actually think they are meant for old and infirm people, not that i am implying anything you understand![]()
it would worry me more if it wasn't conductive and had insulating properties which may lead to bad contact and arcing of the pins and receptors.Qedelec said:Generally switch cleaning lubricant is not conductive so should be ok.
To be doubly safe chack with the manufacturer.
