UNEXPECTED WIRING TO CEILING LIGHT:
Discussion in 'Electrics UK' started by RONCHAM, 12 Dec 2015.
  1. RONCHAM
    RONCHAM
    31 Mar 2009
    256
    Thanks Received:
    Surrey
    Country:
    I have a ceiling mounted light which has the red and black wires from a single T&E cable into its connector block (which is not what I expected!). Would I be correct in assuming this must be from the switch, and somewhere along the way the red (or black?) wire has been tapped into a live feed? In any event, I wish to replace this light with several downlights, so should I not worry but simply extend on from this cable? Also, in this situation is a junction box needed at the first downlight, or is a click connector adequate here and at subsequent downlights?
    Regards.
  2. Sponsored Links
  3. bhm1712
    bhm1712
    7 Jan 2009
    1,556
    Thanks Received:
    69
    Nottinghamshire
    Country:
    If there really are only two wires into the ceiling rose then it's likely the red is live and the black neutral. You will need to measure this using a suitable meter to confirm this. Is there also an earth connection?
  4. Iggifer
    Iggifer
    8 Sep 2011
    4,637
    Thanks Received:
    587
    Warwickshire
    Country:
    If you only have one cable at the light, you either have your neutrals looped at the switch, or there's a junction box somewhere. If you check behind the switch it should be immediately obvious. If its looped at the switch, there'll be 2 or three lots of cables there (assuming a single switch) and if it's a junction box, there'll likely only be one cable.
    You can use click flows if you want, but a decent downlight should be able to take 2x1.0mm/1.5mm and thus negate the need to use any form of JB
  5. bhm1712
    bhm1712
    7 Jan 2009
    1,556
    Thanks Received:
    69
    Nottinghamshire
    Country:
    Just to add, does the switch which turns this lamp on and off also turn another or other lamps on and off as well?
  6. Sponsored Links
  7. RONCHAM
    RONCHAM
    31 Mar 2009
    256
    Thanks Received:
    Surrey
    Country:
    Thanks for all the info. Sorry, my mistake, the earth wire IS also connected to the block. Also, the switch is 2-gang - the second switch is for an adjacent room, the other only turns on the light in question (so the live feed could be off this second switch as lggifer suggested? - I'll check). If not, I would hope it's via a junction box and not some lash-up. My main concern is should I be worried by this arrangement? I've been here 15 years and there's been no problems - so I'm thinking not? I assume I can check live/switch return with a multimeter (and power on).
  8. RONCHAM
    RONCHAM
    31 Mar 2009
    256
    Thanks Received:
    Surrey
    Country:
    Thanks for all the info. Sorry, the earth wire IS connected to the block. The switch is 2-gang and the second switch is to an adjacent room, the other switch only turns on the light in question (so the live feed could be here as Iggifer suggested? - I'll check). My main concern is should I be worried by this arrangement? - I've lived here 15 years without any problems so I'm thinking not? Presumably I can check live/switch return wires with a multimeter (and power on)?
    PS I haven't been on this site for a couple of years - am I thick, it's not obvious to me how I give "thanks" to you all??!
  9. RONCHAM
    RONCHAM
    31 Mar 2009
    256
    Thanks Received:
    Surrey
    Country:
    I'm reading elsewhere that people are getting peed off with downlights - my fault for being behind the times! But at least I'm thinking LEDs!
  10. Taylortwocities
    Taylortwocities
    28 Jul 2006
    20,632
    Thanks Received:
    2,141
    Oxfordshire
    Country:
    Downlights? that's so last century:LOL:
  11. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
