Hi
I own a rental property. It's a flat in a purpose built block, ie not a house conversion. I was called out there recently due to a leak to the flat below, which I disovered came from the overflow of the hot water tank. Trying to adjust the ballcock of the tank I discovered everything was coroded and thought I'd better put a new tank in before the worst happens to the old one, however I'm not sure what to replace it with!!!
The existing tank is a square copper design with what appears to be a cistern type affair at the top where cold water enters from the main and there is a ballcock controlling the flow. It's an economy 7 heater with what looks like a single element, but I'd need to go back to double check this. I should think the tank has been in place since the flats were built some 25 years ago
I've been looking for something similar to do a straight swap but can't find anything. I'm wondering if a need to change it for a more regular hot water cylinder but I'm worried about how it would work with the existing overflow mechanism. Has anyone ever come across something like this before?
Regards
Otourist
Regards
Otourist
