Beware cheap TRVs - they're cheap for a reason and on a communal heating system the last thing you want is the hassle of having to change them again in a couple of years.That sensor head is almost the same price as whole set of valve for some brand. I prefer to change the valve too but the whole system is imperial not metric. I'm happy to get radiators too. What kind reducer/adaptor do I need for connection from imperial 3/4 pipe (cast iron) to 15mm valve?
If I'm reading your Vernier correctly, your steel pipe is ½", not ¾" - steel pipe is sized on its bore, not its outside diameter, and ½" steel pipe is about 21mm o/d.
Couple of options - either use ½" female iron to 15mm compression adapters and a short length of copper to adapt to "normal" valves (but you'll have to move all the radiators up the wall about 50mm) or buy new valves to fit the existing pipe. New valves to fit will be slightly harder to get hold of, but will mean you don't have to sod around moving all the rads.
As Ian suggests though, you're probably better off getting someone in to do it for you. That way it's not your fault if there's a leak when it finally gets filled up again![]()
They are definately not cast ironWe have communal heating in the building and the system currently drained off. The pipe are cast iron. This is a typical set up of radiator.
All TRV valves look the same. There are two types of locksheild valve.
