I'm struggling to make a central heating system work. The problem is, I've got a stone house with the plumbing already installed and it's tricky to add new pipes. Essentially I've got 2 floors and 4 radiators downstairs and 3 upstairs. There is sufficient pipework to run 3 single pipe circuits with 2 or 3 radiators on each one. The expansion tank is high up and the expansion pipe can be the first thing on the hot circuit, but is reached by 3m of pipe under a tiled floor from the boiler, which is on the 1st floor. I have tried to puzzle this out myself, but have had limited circulation, airlocks, and worry about safety as wood burning stoves can't be switched off in a hurry! The diagram attached shows my best shot at making this work and is a configuration I haven't tried yet. I've put the pump into the cold side, so I can have a free run on the hot side to the expansion pipe. I am also concerned about having to route the hot supply down into a manifold on the ground floor and back into each of the 3 single pipe circuits. Will this system work if I connect as per the diagram?
