I have a bit of a bizarre problem with my central heating.
Problem is that when it's on hot water only its gets itself into a weird cycle of pulling air down the expansion pipe and pushing hot water up the fill into the header tank.
It starts ok when cold, but once hot you can hear a whooshing noise as it pulls air down the expansion and pushes water up the fill. It does this for about 10 seconds every minute or so. You can hear the aerated water then going through the hot water cylinder and into the boiler.
It does this on pump speeds 2 or 3 - it's ok on 1 (but then not very good for fast heat-up of radiators!).
Configuration is:- boiler - expansion pipe(22mm with straight of 'T' going to expansion tank) - feed pipe (15mm pipe about 150mm from expansion) - pump - 3 way valve.
I suspect that it has been doing this for a long time, as I have noticed the expansion tank hot before. However, we have just had a new boiler fitted which is now in the kitchen (was in utility) and the noise of the air going through the boiler does not please me!
Hope this makes some sense and that someone can help.
It has been suggested that I convert to a sealed system, but as the current system is about 25 years old, with pipes buried in concrete floors, the thought of putting it under any increased pressure fills me with dread!
