Unvented cylinder output
3 Apr 2016
Hi all
Please excuse my ignorance -
Hypothetically, 20l/min from cold main, into unvented, what can you expect to come out a thermostatic mixer shower?
I mean once the water is mixed to reduce temperature to 40degrees so will have both hot and cold.
Too many variables - type of shower head, supply pipework restrictions, isolators, valve body itself ........
Normally the shower valve specifies the supplies needed. BTW 40 degrees is a cold shower.
40 degrees is cold??? I set the thermostatic thing to 40 and it is red hot???!
In normal conditions would you expect it to provide enough water to adequately use a big shower head maybe 20cm sq?
Min/Max supply flow rate and pressures are specified by the shower valve manufacturer
Cheers mate, it's a triton excellente shower I want but can't find any numbers that mean anything to me!
You can't get out more than you put in! If your cold main is 20L/min, that's the most you'll get out total. However, if you follow previous advice and fit an accumulator as well as the unvented cylinder, you can expect significant gains on that
Yup cheers muggles. Going to go with the unvented and see how it is with new bathroom knowing there is that option if I'm not happy. I reckon I will be though.
What finally killed the combi for me was thinking I have a little ensure and a main bathroom, I might as well lost the en suite shower completely with a combi as I wouldn't be able to use it at the same time as the main shower anyway!
Back up yes but no real point other than that
And no muggles I understand I can't get more than that but wondered if it would be significantly less than 20 or more or less the same as 20
Also if you were running a bath with both taps wide open would they combine to make 20l/min (or whatever it was after pipes valves etc) so 10 each?
Approximately, yes, although you'll get a bit of flow restriction due to friction in the pipes and restrictions caused by valves etc
Ok cool thanks muggles. That's pretty slow but I don't know what I was expecting really! I'll measure them again now
Muggles on that point? If only cold is open is that at 20? And if only hot is open that's also 20?
Then as you open 1 slowly the other decreases until they match when fully open?
