Hi guys,
I have an unvented cylinder that I had fitted to my 1980's build house a couple of years ago. The incoming mains to the cylinder was also upgraded to 22mm at the same time.
All has been fine but the last couple of days when filling the bath, the flow rate and/or pressure (I know these are often confused!) gradually decreases to the point that if I then turn on another tap the flow almost stops.
What I have also noticed is that when the taps are turned off, I can hear the cylinder filling up in the airing cupboard for a minute or so afterwards implying to me that the cylinder has been emptying quicker than it has been filling, which seems strange as I was under the impression that the incoming mains water was what caused the hot water to come out.
Anyone got any ideas what is going on? Is something the matter with my system or is it likely to be something up with the local mains?
Thanks in advance!
Burt
Thanks in advance!
Burt
