- Joined
- 1 Mar 2006
- Messages
- 19
- Reaction score
- 0
- Country
Hi - please help if you can
A year ago I had a very old vented system replaced by a Worcester boiler and a non-megaflow unvented cylinder (I think its a Prostel). This has been fantastic - great shower in the main bathroom. Bath fills fast. Hot water at mains pressure/flow rate. Terrific.
A few months ago we had a loft conversion carried out and got the builders to install a simple Bathstore shower in the ensuite. No electric buttons etc, just a diverter valve to go to the rain head or the handheld shower attachment.
http://www.bathstore.com/products/metro-thermostatic-shower-valve-271.html
They took hot and cold pipes from the airing cupboard in the bathroom one floor down and routed these to the ensuite which is one floor up and about 4 metres along.
The issue is that the flow rate is disappointing in the new shower. it is quite a bit less than the main bathroom which surprises me as the height difference is not that great. I was expecting mains flow rate.
I have removed the two flow restrictors in each of the shower heads in the ensuite. This helped a bit but the two showers are very different in rate.
Secondly - if a bath is run downstairs and someone tries to have a shower upstairs, no water comes at all, in fact the pipes drain back I think because when the bath is complete and you try the taps upstairs again, you get all sorts of explosive ejection of air first!
Is there anything obvious I should check about this? Should the height make that much difference? Is this a known thing which simply cant be fixed? Are there any restrictors in the thermostatic valve panel itself?
Any suggestion would be much appreciated. Thanks!!
Wes
Wes
