What is the max temp I can safely heat an unvented cylinder to without issues? My current immersion stat stops at about 63 degrees.
I have a TMV on the outlet to mix down to 40 degrees.
Which immersion stat is best to use?
Its heated via solar so the more energy I can pump in the better. Im thinking of adding a water softener to stop limescale build up.
Thanks!
Thanks!
