- Joined
- 14 Jan 2007
- Messages
- 17
- Reaction score
- 0
- Country
my brother has moved house and whilst moveing him in we found the hot water temperature very very hot,to hot to touch,steam and bubbles from hot taps.
after reading posts here i have checked.
1,the immersion heater is off.no immersion exists.
2,boiler stat is in mid position.suprima 100.(poor sod).
3,no primary flow is getting past 3 port valve port b.when on heating only mode.
4,cylinder stat a sunvic has no or is missing any adjusting dial,this looks like the problem.
ok am i correct.
just another probaly daft question,what is the reccomended hot water temperature at the taps.
if i set new cylinder stat ar 60 degrees will hot water temp at taps be 60 degrees.
once again thanks in advance.
ok am i correct.
