Unvented water heater
16 Apr 2009
Derbyshire
Can anyone recomend a good unvented (under sink) water heater to feed 1 kichen sink tap, 1 bathroom sink tap and bath.
I caln't see the pipe run being any longer than 4 meter.
Thanks, Richard
No undersink heater will do what you want.
Ave bath holds 150 - 200litres @ 42 deg. Biggest undersink 30litres = very shallow bath :!:
You need an unvented cylinder to feed what you require.
Will that do away with the Header tank and will it make the hot water pressurised?
Thanks Richard
yes but theres certain points that have to be taken into consideration.eg incoming flow pressure,location of d1/d2 pipe etc.these should be discussed by someone who has an unvented ticket.believe it or not you have to have one even if you fittted the 30L undersink heater.
And would it be possible to buy one which will also feed sentral heating? I take it I would be looking at an in-direct cylinder thow!
yep you can get indirect.the other option is a thermal store.it doesnt need an unvented ticket to fit em and are more tolerant with incoming pressure/flow issues.personally though, unvented all day long.
