Unvented water system - hot pressure variable
7 May 2006
London
I've got an Ariston unvented waterstorage sylinder, attached to a Worcester-Bosch gas boiler.
Recently the hot water has been playing up, but I cant understand why. The boiler is firing up and heating the tank as expected, and sometimes the hot water comes out fine, other times it goes cold after a short time. It's especially bad in a loft shower room.
Any ideas?
Paul
Could be unbalanced supplies, you need a suitably qualified engineer to service an unvented.
Is it only the shower that has a problem?
Agreed. Has a balanced cold been taken off the system AFTER the combination valve? If not it might be causubg you issues.....plus the shower mixer may be fault and the cartridge needs reapir/replacement
Thanks for your responses. It's worst at that shower, but unreliable everywhere. I just gave the kids a bath, and we have a thermostatic mixer tap, pretty much as soon as I turned the tap off, the hot feed felt freezing.
Is that consistent with an unbalanced system?
I will get someone in, but prefer to have some ideas first.
Not sure whether it's related, but there is a slight hissing at that tap occasionally also, could that be the cause?
Paul
It's possible you have a mixer tap letting the cold by if the system is not balanced on both sides. Has a check valve been fitted on all hot outlets or just on the hot out the tank? Finally it could be faulty mixers but i can't see all of em going faulty at once so my guess is non balanced with a mixer tap letting cold by
Thanks for your feedback.
I prefer to have views from someone else when I call in an engineer.
I guess it could be a dirty filter, or because the cold feed isn't taken from after the pressure reducer.
Does anyone have any suggestions of reputable engineers for unvented systems in SE London?
Paul
