Hi all.
Some time back my old boiler was in trouble, so I got a quote for a new one. As you're probably aware, it's not just a case of a new boiler, but all the accessories as well (TRV's etc.) In the end the cost was prohibitive, so I had the old boiler repaired instead.
Anyhow, now I'm having some renovations done, including removal of the wall on which the boiler hangs. So, I thought now's the time to get the new boiler.
First up is the old "to install a combi or not" question. My current sytem is open vent, and the last heating engineer I spoke to recommended staying with that unless I need the space where the water cylinder is (I don't). But, I am sorely tempted to rip the header out and remove the cylinder and go this route, the main thing stopping me is that I am not sure my showers (two of) are compatible. The are both the "pull-cord" with their own electric pumps. Thoughts?
Secondly, the quote I had was for new everything, save the radiators, which I wanted to re-use. But what is wrong in re-using the other parts such as the pump, water cylinder, 3 port switch, programmer etc?
I can also see the case for renewal using the age argument (my stuff is 20 years old and more), but I'm wondering if all the parts could be replaced by newer, second-hand parts? For example, I have seen a nearly new replacement cylinder for 35 quid and pumps for around 30.
The quote ends by saying "assume loft lagging is a minimum of 100mm." Presumably, I should check this and think about fitting it if this is not the case?
Final question is about TRV's. My radiators appear to be 15mm x 3/4" and all the TRV's I can see are 1/2". I read something about a bush or convertor - can someone elaborate on that. Also, Do I need new lockshields on all radiators too (not sure if I have these already).
Many thanks,
Mandy
Many thanks,
Mandy
