B
breezer
you speak from your experiance, i speak from mine.
kendor said:I think you should be aware of what the minimum internal resistance of the batteries could be when both where discharged as this will determine the charging current as lead acid chargers unlike nicad chargers are not constant current sources, i would worry whether the secondary winding of the charger's transformer would be of sufficient current capacity so check first as it could be an expensive mistake otherwise!
Do you use an invertor to convert the battery power into mains to drive the UPS? or are these batteries in parallel with the internal batteries in the ups?andrew2022 said:kendor said:I think you should be aware of what the minimum internal resistance of the batteries could be when both where discharged as this will determine the charging current as lead acid chargers unlike nicad chargers are not constant current sources, i would worry whether the secondary winding of the charger's transformer would be of sufficient current capacity so check first as it could be an expensive mistake otherwise!
thanx for the advice every1
current setup:
4 50AH bateries in parallel. these are charged from their own charger and connected to the main UPS by a 70A relay which only changes if the mains fails. in which case the charger would be off so that cant do damage to the UPS
total run time: got sick of the beeping after 8 hours
kendor said:Do you use an invertor to convert the battery power into mains to drive the UPS? or are these batteries in parallel with the internal batteries in the ups?
you are likely to get a brownout
CallEdsFirst said:I would hope that fusing prevents it from supplying 207 amps for 1 hour!!!!![]()
