3 out of my 4 top floor radiators refuse to heat up. The one that does work is immediately above the boiler and I suspect may be on a different flow. It is an open system.
The radiators will bleed so that water comes out of them. Occasionally there is some heat gets to the intake pipe but rarely goes much further. They used to work fine, but haven't worked properly since I started trying to use them again as the weather has got colder.
I've read elsewhere in this site that this can be caused by stuck gravity check valves. If this is the case, what does one of these look like and what should I do about it?
Grateful for any advice.
