I'm planning on overlaying my garage roof tomorrow (weather permitting) with three layer torch-on felt. My primary question is about the upstands.
There are 2 or 3 courses of brickwork around the back and one side of the roof. The previous felt upstands passed right through the brickwork with the top course laid on top.
One quote I had suggested fixing 50 x 100 mm tanalised timber to the top of the walls and forming the upstands over the timber. That sounds a better option but exactly how would I form the upstands? Bring the top two layers over the timber and say 150 mm down the other side, torching all the way? It's an external / boundary wall so this is possible.
Also, I presume this is the way to do the work: -
Pierce existing blisters, flatten existing felt as best I can
Remove existing upstands.
Tidy existing brickwork and fix timber on top.
Sweep existing roof clean of debris
Cover with bitumen primer.
Loose lay ventilating underlay with no overlap following fall of roof.
Torch on middle layer across fall of roof starting at bottom.
Torch on top layer as per middle layer.
Any other handy hints? Seems frustratingly difficult to get a good 'how-to' guide on felt roofing!
Thanks,
Mark
Thanks,
Mark
