UPVC Door handle . . .
12 Jul 2008
Wiltshire
My door has a handle and off set pad, I'm after a replacement and have been to B&Q and Wickes but can't Sean to find one. Does anyone know a shop I could go to to get one?
Thanks all.
I've been looking on a few sites and cant find mine listed.
I have a Lever/Pad set up offset with the pad a greated distance from the centre of the key hole.
My measurements are:
Lever to Key hole:- 68mm
Pad to key hole:- 90mm
Any advise where to buy would be greatly receiced!
I'm at a loose end with this. They all seam to be the other way round to mine.
Posted: Sun Nov 06, 2011 9:22 pm Post Subject:
What do you mean exactly?
A:- The link alarm showed you has the handles that would fit on a door that opens on the right hand side,if you were looking at the door from outside(hinges would be on the left side of door)
B:-Do you mean the pad side is higher that the lever side as the photos show it as pad lower than lever?
C:-The handles will fit either left or right hand opening...all you do is rotate handle 180 degrees.
Hope this helps.
Rob.
I've removed my handles and taken them to a local independent hardware store, and they have advised me that they are obsolete. The doors only 8 years old. They have said I may be able to change te gear box, any advise on this?
Hope this helps.
Rob.
B. yes the pad is higher than the lever.
Heres a few pictures - thanks for your help guys.
**EDIT: ON THE METAL STRIP IT SAYS BOWATER WINDOWS IF THIS HELPS?**
Just to recap... Outer pad doesnt open door without key and is a greater distance from keyhole
Inner handle opend door and is closer to key hole
Thanks for the links. That 70-92 would have been good but its obsolete. This this is the troublenive been having :(
I don't mind having levers as long as works the same and doesn't open from the outside
Only thing I can suggest after calling a m8 is the universal lever/lever.
( He has his own locksmiths shop, 48 yrs in the game and says no chance:-( )
