Hi All,
I am a newbie looking for some help with a broken door lock. Here are the facts, I hope someone can offer some advice:
Door is upvc hinged type.
Door is open.
First problem, could not turn key in lock when trying to lock door from the outside.
Secondly, key could not be removed from lock.
Thirdly, snapped key when trying to solve above.
Spare keys on hand.
Lock barrel is only 4 weeks old having been replaced when one set of keys were lost (only info, do not think it is relevant).
At first I thought I could simply remove the lock barrel by removing the screw on the edge of the door, but I forgot that to remove the barrel you have to be able to turn the key to align the lever inside the door (I hope this makes sense).
I then hoped I could use the spare key on the inside of the lock but it does not enter fully probably due to the other snapped key being inside the barrel.
Result is I cannot lock the door, remove the snapped key or change the lock.
It is not an emergency as I can chain the door locked from the inside. I would therefore seek some advice for a diy fix before I employ a locksmith.
Thanks in advance
Door is open.
Spare keys on hand.
Thanks in advance
