UPVC double glazing .. Expansion ?
12 Nov 2010
Renfrewshire
Hi, newbie here
My existing wooden framed windows have reached the end of their useful life and i've decided to have a go at replacing myself with some UPVC units, starting with a few of the smaller ones as a trial.
On one of the windows (1.4m wide , 1m hieight), i jammed a length of wood (very tightly) between the top of the frame and the concrete lintel above to secure as there seemed to be excessive movement in the top of the frame, when the window at the top of it was opened / closed. The piece of wood runs the complete width of the frame. I also screwed through the frame from the inside through to the wood to further secure and prevent movement
However, someone mentioned to me that i could experience a problem with expansion of the upvc as I have allowed for no movement in the frame at all. I wasn't aware of this at the time and am now worried that i may have a future problem with the window which i jammed with the wood.
Can anyone advise how much the frame is likely to expand and is there a danger of the frame bursting / or breaking the glass unit? Do i need to re-expose the frame and remove the wood and secure by some other means or can i just leave as is ?
I'd appreciate some advice, thanks
If they are white windows you should be fine, not much expansion on white, dark woodgrain is another matter!
If possible you should get yourself a foam gun and fill the expension tolerance, approx 5-10m around the frame with foam, double joy as you 'fix' the frame and allow for expansion.
thanks for the quick reply
The windows are made of white upvc, which are Brown on the outside (foil covered)
I'm not keen to have to re-do this window as i have already finished off the insides so would take quite a bit of work. However i am happy to do it if there is likely to be a problem.
Is there likely to be much expansion, given the size of window and is there likely to be a problem ?
I doubt the glass will break, theres quite a bit of space between the frame and glass, I'd be tempted to leave it and see how you get on.. I've fitted tight windows without any trouble later BUT that said its only you that knows if they can live with it or if it will do you head in!
