I’m new to the site so forgive me if this has been posted before or if my terminology is incorrect.
I have a ‘tilt and slide’ patio door with a broken locking system. The doors has regular sliding bolts on all four sides, at present the handle and key lock edge is the only one that actually actuates the sliding bolts on that side of the door only.
On investigation, it appears the drive corners are the problem. The thin flexible metal strip that runs in a channel to push and pull the next set of sliding bolts has snapped on each of the drive corners.
Is it possible to get these repaired or replaced or even get hold of the type and size of flexible metal strip to make the repair myself. So far I have not seen any manufacturers name anywhere on the door or locking gear.
