UPVC Window Gap - Not Flush With Frame When Closed
  • Thread starter bob-the-builder
  • Start date
It may be that the hinge has been sprained from an attempt to get in the window or could be if the window was closed and there was a foreign body in the track at the time. Check to see if the hinge has any misalignment or deflection to it and if so straighten it out . You may have to remove it do so. The hinges are not too much to buy either so a better option may be just to pop into your local window manufacturers with the hinge and see if they can supply you with one.
Here is a supplier if you get stuck :
http://www.handlestore.com/frictionhinges.php
