Hi, builders are installing a new window and sliding door in to new extension, looks like they just put expanding foam around the entire inside of blockwork and then put window and door inside.
Then screwed in frames and proceeded to insert glass etc..
Don't they need to use some sort of plastic pieces in between the outside of the frames and the hole in the block wall? What are those pieces for?
Help!!!
Help!!!
