USB Sockets and Bluetooth receivers
26 Apr 2023
I've brought a couple or Bluetooth receivers which are usb powered. It was impossible to get them working at first.
I eventually got them working, but with a different usb socket - the same or lower ampage rating.
Does anyone have any idea what is going on here?
Maybe try with a non data cable. Just a power USB cable
They are they type that plug straight into the USB socket.
I tried without a usb extension in case that was the problem.
Usb a plug one end to usb c plug the other?
Some charges sense what's going on more than others. They are chargers not power supplies.
Maybe one of your chargers thinks the phone
( it's not a phone I know) Is charged as not pulling much power so switches off.
I have an alarm clock that's running off a phone charger. It don't work on some because it switches off.
Look up.
Differences between a USB power supply and a charger
It is a USB A integrated into the receiver.
I understand what you are saying about the power supply vs charger.
I wanted Bluetooth receiver because I've got a Bluetooth transmitter & receiver and I have to change over to receive every time I switch it on.
I thought it would be a simple case of swapping them, but the usb plug* that was working fine is the one that doesn't work properly.
...all puzzling so far.
(*and the type I have most of)
