An "interesting" assertion.Shaver sockets usually have universal recepticals on them which take US, Euro, UK 2 pin, and sometimes Australian plugs. They certainly work satisfactory in my experience for the low loads they are designed for.
BS 4573 / IEC 60884-1 shaver plugs are not the same as CEE 7/16 Europlugs
CEE 7/16 Europlug pins are 19 mm long. They consist of a 9 mm long conductive tip of 4 mm diameter with a rounded ending, followed by a 10 mm long flexible insulated shaft of not more than 3.8 mm diameter. The two pins are not exactly parallel and converge slightly; their centres are 17.5 mm apart at the tip and 18.6 mm apart at the base.
They can be inserted into any socket that accepts 4 mm round contacts spaced 19 mm apart.
BS 4573 / IEC 60884-1 shaver plugs have larger pins (5.08mm) which are closer together (15.88mm).
