- Joined
- 4 May 2011
- Messages
- 2
- Reaction score
- 0
- Country
First post, so hello, and sorry, I'm another person who only signed up because I need help with something.
I had a couple of rooms plastered about 5 weeks ago. The plasterer applied GTEC Smartmix Xtra - Joint Cement. The rooms, previously, had wallpaper over plasterboard.
Few days ago, after giving the plaster a light sanding, I used Durabond PVA as a primer but did not realise the product required dilution for this purpose (recommended ratio is 4 parts water to 1 part PVA). The next day I applied the first coat of Dulux Supermatt water based emulsion (applied neat). I didn't think there was anything out of the ordinary when the paint dried to a cracked mud effect finish as it was the first coat. Now that I've applied a second coat, only to be left with the same effect, I'm... concerned.
It was suggested I lightly sand a test area before applying a slightly diluted coat of the emulsion to it - to see whether this solves the mud-cracking issue. Is this a reasonable course of action? I'd like to hear from someone, in the know, as to whether this needs to be tackled in a different way in order to avoid future/more complicated problems.
Thanks in advance.
Thanks in advance.
