using a 15 degree plus roof window on a 10 degree pitch
TP1
11 Nov 2011
Surrey
I have put two 1600 x 940mm roof windows onto a 10 degree pitch roof. I have used 5 degree upstands to meet the required pitch. It looks terrible, on top of the 150mm upstand, the additional pitch completely destroys the aesthetics of the build.
As far as I know, there are 3 options:
a, Drop the roof windows down to 10 degrees and lose warrantee from roofers and Wickes roof light.
b, take out the flat windows and replace with dome windows, which will cost a fortune
c, Deal with it.
Can anyone advise?? Rapid answers would be much appreciated...
If I seal the windows to prevent them from opening and then seal it further with mastic etc, will that safeguard the roof windows against leakage if I drop them down to 10 degrees????
take them back get your money back and buy some flat roof windows. velux or mardome and stop trying to bodge it.
Presumably you are using a flat roof material at this pitch - so you do need a flat roof skylight.
Pitched roof skylights are not recommended on low pitches because you can't flash around them properly without them leaking, it's not because of the window itself.
