Using mortar tone - which sand
5 Dec 2012
I have decided to use standard mortar mix for pointing my patio purely from a cost point of view
I’m adding some everbuild mortar tone to the mix to give it a bit of colour
Is it best to use building sand at a ratio of 3:1 sand:cement (with a bit of mortar tone)? Or sharp sand?
Am I correct in saying that I only need a small amount of water to make damp but not wet?
Cheers
Cheers
Below dpc and on a roof, 3:1 is the correct ratio. Above dpc, 5:1 is adequate.
A repointing mix has to be drier than a bricklaying mix, otherwise you will smudge your bricks. If you use a mortar gun, follow the guidance on using lime, otherwise the mortar won't come out.
I won't supply exact detail, because, it's a DIY forum, so love and learn but hopefully I've pointed you in a better direction.
Make a few test batches at different mix ratios (and use a weighing scale / teaspoon measure) and let them cure a long time before deciding which to go for. Round my way building and sharp sand are completely different colours and this has an impact on the end result
And building sand varies massively in colour depending on the supplier.
A mate of mine is an extremely good pointer over the years he has got to know which retailers sell the colour of building sand that he wants.
