I am wallpapering a bedroom in the house i am using a patterned wallpaper i have been reading up of how to do wallpapering around corner so i had a clue i what i needed to do. What i did was put about 1 inch of paper around the next wall then butted the off cut lenth upto the wall but the pattern is off now. do you allways butt the off cut upto the wall or can you just overlap it a little bit to try and get the pattern as good as possible . All i wanted to know will you always loose the pattern in all corners? or is there somthin i am doin wrong? when the paper over laps the other paper do you just leave it like that or do you trim into both wallpapers then peel them back the butt them both together. This paper has alot of pattern so i think it wont look right if i cut into the overlaped paper. what do you all think is the best way?
many thanks
many thanks
