I plan on converting a small area of my property into a utility room. Just to get to move the major appliances out there & another sink - no room for toilet or anything major!
This is the area I wish to convert :-
I guess it was built by the previous occupiers.
I have 2 questions really :-
1. Water Supply & waste - The easiest place for me to take a water feed from is the bathroom sink, as its directly above the roof on the left hand side.
Could I use polypipe or something similar & split the water from my bathroom sink? My biggest concern is could it damage an appliance if it was in use (ie a washing machine) & someone turned on the cold tap?
2. Heating
As you can see it has a box profile polycarbonate sheet roof. So it can get cold in that area - I was thinking of 2 options.
install a radiator or install electric underfloor heating.
Underfloor heating is the easy option, a radiator is possible, but would mean the feed & return pipes running along my living room wall & making things look a bit messy.
My biggest concern is a burst pipe or something in the cold weather (though touch wood, I have an outdoor tap at the far end of the garden with lagging on it which has not burst yet! - that was there before I bought the place.
can anyone give me some pointers if what I want to do is straight forward enough? There is already lighting & electricity, as the previous occupier used to run a small cab firm from within there.
2. Heating
