Vailant ecotec plus 824 no heating or hot water
14 May 2012
Bristol
Hopefully you wonderful people can help. :)
We have a Vaillant and since it was left turned off overnight we now have no hot water or heating.
There are no fault codes, the pressure is fine but the screen shows 0 degrees c. When pressing I it shows s.0 (no heat required).
Turning a hot water tap on does nothing as does turning the Danfoss rx1 thermostat.
What can I do?
Thanks in advance.
Simon
have you got both the control thermostats turned clockwise ?
Yes and the C is on to say that it is set for instant hot water.
When moving the dials the target temp changes but the screen still goes back to 0 degrees
It shouldn't show 0 deg
Are you sure it doesn't say F 0
Your gonna need an engineer
You will still need an engineer.
Sounds like a failed PCB. If so a fixed price repair deal would probably be best.
Tony
