    Dismiss Notice
Vailant Turbomax 282E - Intermittent Hot Water
Discussion in 'Plumbing and Central Heating' started by Peterle, 6 Oct 2011.
  1. Peterle
    Peterle
    6 Oct 2011
    3
    Thanks Received:
    Manchester
    Country:
    Hi
    Just looking for some advice please.
    I have the above make of central heating boiler.
    When the hot water is called for sometimes it produces hot sometimes it doesn't.
    The system is on contract with british gas. I had this same problem about 18 months ago and BG were called out. The engineer said that there was nothing wrong with the boiler and that the fault was more likely a faulty mixer tap and that cold water was getting into the hot water circuit. Literally over night the fault cleared and has been fine ever since.
    The fault has just returned and I feel reluctant to call BG out again (or should i?). I just wondered if any experienced boiler engineers had any thoughts (I'm an electrician by trade so no boiler experience as such).
    I understand that I could isolate the cold water/mixer valves circuit to prove it, but it is a bit of a pain getting under the floor.
    I read somewhere on a forum that the Vailant Diverter valve, microswitch or diaphragm can cause such a fault?
    Would appreciate any ideas??
    Peter
  2. Sponsored Links
  3. lightning
    lightning
    14 Jul 2007
    2,051
    Thanks Received:
    444
    Cambridgeshire
    Country:
    If your paying for a service get them out to have a look
  4. spraggo
    spraggo
    6 Sep 2010
    947
    Thanks Received:
    151
    Avon
    Country:
    What you read is correct, tell the BG engineer that and he will think that you know more than him ;) ;)
  5. Agile
    Agile
    26 Jun 2004
    63,724
    Thanks Received:
    4,545
    London
    Country:
    You need to ecplain what the fault symptoms actually are!
    Does the boiler fire up when you turn on a hot tap?
    If its the diverter valve the switch can be seen not to be making and the boiler will not fire up.
    Tony
  6. Peterle
    Peterle
    6 Oct 2011
    3
    Thanks Received:
    Manchester
    Country:
    Thanks Guys for the replies...
    Working from home today, so looked at this in more detail..
    Although I have these very same symptoms before..I have recently had a new kitchen fitted and I've got a feeling that the builder may have the water connections the wrong way around..(ie incoming Water mains supply connected to the DHW out)..Difficult to tell because after the stop cock, the pipes go up and over the ceiling before supplying the boiler. So cant trace the pipes visually..
    I might get chance to swap them around on Sunday, but then away with work...the week after.
    Will keep you posted
    Peter
  7. Peterle
    Peterle
    6 Oct 2011
    3
    Thanks Received:
    Manchester
    Country:
    Quick Update:
    Managed to get under the floor today; the pipes were crossed. All working well now.
    Thanks for all replies; much appreciated.
    Regards
    Peter
    PS - I work in IT now and if anyone moans to me that plumbers charge too much; I'll explain how it feels lying in two inches of water, I wouldn't do that again for £100/Hour!
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
