Hi there,
Could someone please shed some light on my boiler nightmare.
I have a Vaillant AquaPlus, fitted 2.5 years ago. 4 months ago, hot water was running to luke warm, then eventually turned to cold. Heating then packed up too, leaving F.24 fault code on display. Called the out the guy that originally fitted it, he suspected that the diverter valve had gone, he called Vaillant technical support, who backed up this theory. So a new diverter valve was fitted, the system was up and running shortly after but he advised I have at some point the system power flushed. I had this done 2 weeks ago, since then, I've noticed the rads are hot at top and around edges, but warm/cool in the middle and bottom, normally I've read on this forum denoting that there is possibly sludge in the system. The water has gone again a week after power flushing, and the F.24 code has re-appeared. My plumber has been back on several occasions (for free) to try and sort this problem out for me. He has installed and inhibitor, as hard water is a high level here, he has cleaned heat exchangers, changed the hot water thermostat and checked the pump. I've read that it could be the APS, one person wrote in to say that her APS was faulty and this was (apparently) a common fault on Vaillant boilers - could this be true? I've mentioned to him. He called Vaillant to see if they would support this claim, but they said that the internet forums weren't reliable!
Please, please could somebody shed some light on this for me, as reluctant to call out Vaillant engineer at this stage, as come so far now, there can't be much more to check?
Thanks in advance
Emma
Thanks in advance
Emma
