I recently emptied some water out of the central heating system, to put some inhibitor in. Then I topped up with the filling loop to get to the 1.5 bar pressure. But now when i turn on the hot water tap a banging noise comes from the boiler.
The noise sounds as if there is a metal piece flying inside the boiler and hitting something. It only happens when I turn on the hot water and the boilers ignition turns on. The boiler is a vaillant combi 831 on a sealed central heating system.
This never happened before, and the boilers been working fine for last couple of years.
What could make the noise?
