I have had a new Vaillant combiboiler Ecotec 838 fitted together with new copper central heating pipework. The whole system is new. It works well except for a noise like a motor coming from the system from time to time for about 10 minutes and then stops. It is difficult to say where the source is but could be from the boiler. When hot water is called for it stops, and then resumes once hot water tap is closed. From cold in the morning the boiler is silent until it reaches near the set temperature on the external thermostat. Can be about 1.5 hours. The noise then starts on an intermittent basis. I am only putting on 2 or 3 radiators on at a time as we don't need to heat up the other rooms. We have 3 bedrooms, 2 reception rooms, kitchen/diner and 1 bathroom upstairs. The bathroom has a towel rail with on/off valve which I leave on. I understand the boiler has a modulating feature which adjusts the pump flow rate to suit the number of boilers turned on. Would anyone be able to offer advice on how to eliminate the noise sounding like a motor. We do not leave the heating on at night as the noise wakes us up.
