Vaillant ecopro max 28e
boilers more than adequate for your needs apart from the facia its a glow-worm hxi so you may consider one of these as they are normally a couple of hundred cheaper.
What did this mean then, 'Yes its a very good little boiler', and 'Unless your house is huge it should do nicely'?
If you're really stabbing in the dark why not get a pro to come and explain- or are you thinking of taking it on yourself?
I would suggest you pick a few potential installers and let them recommend two or three possible replacements.
I dont "recommend" boilers because I believe that the client who is to pay should make the final choice. Instead I "suggest" two or three possible solutions and point out the pros and cons.
Usually the choice is between cheaper or more expensive makes. I try to suggest a cheaper, mid range and expensive make and let the client choose according to their preference.
Which political party would I stand for? Green party because they support condensing boilers, Labour because they want us to fit them or Conservative because they dont know what they are?
Tony
Well if you stood for the lib dems, the leader might stand you a drink (or three!).
